Motor Dies When when I pull clutch
Rebus
So motor is badass runs excellent. Only problem is. It dies when I pull in clutch at stops. Otherwise its a beast. Idle screw seems to have no results. Ive troed it on the first 3 needle settings. 2 was first. The way it came. Dies when clutch is pulled. I went to 1. It ran shitty. Bogging. 3 is running excellent. Just simply dies. It acts as if the clutch os the kill switch lol. Please help
With engine off can you push the bike forward with the clutch pulled in?
Does it feel like the clutch is still engaged?
Adjust the clutch
How's your S/P look Gotta pic?
It rolls perfect with clutch pulled in. When clutch isnt pulled in. Wheel will eventually turn instead of drag, but it starts and runs fine.
Sounds like a tuning issue, you may need to raise the slide in the carb a bit so that when it's at idle more gas will flow to keep it going.
