Gerard jones
Hi guys, first timer here.
I ran this bikeberry 49cc very nicely until it injested rust or dust from the tank, it clogged the carb, I clearned it out and it ran ok but I still noticed black dust in the fuel line. I installed a better filter and rinsed the tank out, no more junk in the line but now it won't run without some choke.
Today I pulled the carb again and ran wire thru the jets and blew everything out with compressed air.
Painted the used gaskets with some indian head gasket shellac, still no dice, only runs with half choke, wont idle and won't take gas or rev up once choke is off it just bogs down.
All the youtube videos infer this to be a fuel starvation problem, makes sense considering it ate dust but I can't get the jets cleared, I pulled the float jet and idle jet on the carb exterior. Not seeing any clogs but there are jets I'm sure that can't be seen.
I replaced the chinese plug with NGK , no difference.
Fuel is good, fires right up with choke but then revs way up high even at low throttle with the choke engaged.
Turn the choke off and rpm drops to idle , then dies, it will only recover if I apply choke again.
I'm thinking to toss in the towel and get another carb, this might have crap where I can't remove it.
Any other suggestions?
