I have an 80cc engine kit, i cant ride it cause it wont come free even if you press the clutch, releasing clutch locked, pressing clutch is locked too.. pls help.. thanks..
First press the clutch arm (the part that is sticking from the engine) directly and see if it the wheel can rotate- if so then your cable is too loose.
If that is not the case take the sparkplug off and try again- if the wheel still can't turn, even toghether with the engine, most likely the chain is hitting the sprocket cover. Take that cover off and look for rub-marks and visiblle high spots and grind or file them away.
If that also isn't the case then you probably have a stuck clutch. You can free it up as explained here: https://motorbicycling.com/threads/clutch-cable-and-clutch-adjusting-procedures.22726/#post-215612
