so i messed up my original cylinder body in a way i wouldn't like to admit, so i bought a new one. it was a very simple swap but now my engine will crank but wont turn over. i know fuel and spark work because on the old cylinder it was fine, but i tested them again just to make sure. the only difference on this cylinder being that it is 2 mm shorter in stroke length, i dont know if the stroke length is mission critical but that is the only variable i didn't change. ive read that some spark plugs dont work under higher compression, ive ordered a new one already though.
Important note - i did get a single combustion once or twice while screwing with the choke when trying to start it, it was like a single puff and smoke came out of the carb side. everything was mounted in the right direction.
ill list here everything i tried
running it with the choke down for a while
refilling gas tank (more pressure?)
riding around the block with the clutch down to "clear out the engine"
making new carb gasket out of rubber
adjusting the air/fuel mix in every way
taking off exhaust
testing the sparkplug (works fine)
taking off exhaust
