The engine will not idle. I'll look at the tank for trash.. I guess I'm relying on clean parts.
More info from you. We are not psychic.
A pic of the left side of carb.
How long have you run the motor?
Did it ever run right?
Do you have the choke in the correct position?
Those carbs have small jets.
Captured under the black idle screw is a black plastic block that is the idle jet.
Also some carbs come with a brass plug blocking the air fuel adjusting screw that needs to be removed by drilling it out.
Which kit do you have?
What gearbox is on the motor?
Where did you buy it from?
