What you describe sounds like 4 stroking. It can certainly 4 stroke at one throttle range and not others (at the top end or at the bottom end) The fact that the plug is dry don't mean much since that is where ignition occurs, the color is a better indicator, a dark black indicates a rich condition and a white indicates a lean condition, light brown is good. Also, you should remember, it can still 4 stroke and not have excessive smoke. If you do have excessive smoke that usually means that you are running very rich and might have to jet way down or that you are running a very oil rich gas mix. But it sounds like you are almost there, just make the jet a little smaller. But before you do that, take care of the gasket, and test it for any change. It's certainly possible that you will see a change with a larger gasket and won't have to change the jet at all. I don't think you should try no gasket and just attempt to make it extra tight, you could strip the threads and it still won't work, at least not for long, you have to have a gasket on there. In the old days guys used to cut them out of cereal boxes, haha, and some guys still cut their own. This guy cuts his own and sells them on ebay-->
http://www.ebay.com/itm/Upgrade-Mot...848090?hash=item41c25e831a:g:BsUAAOSwhlZYublL I've gotten some from this guy before and he will combine shipping costs if you buy more than one--->
http://www.ebay.com/itm/Motorized-B...850934?hash=item3f50577e76:g:GhYAAOSwA3dYG8g~
It is good to make your own jets. I think it's better that way. Do you have extra jets or just the stock one? I think the stock one is a #70. Here are some slightly smaller ones if you don't want to mess with making your own.--->
http://www.ebay.com/itm/281779435448?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
