Fengist
Ok, so I've built my first bike, I'm in the middle of breaking in a Chinese 2 stroke. (I'm sure everyone but me follows the rules during break-in) and I'm having one issue and one concern.
Issue: At higher speeds with the throttle wide open, it stalls out. It's like it's getting no fuel. Once it slows down, it will speed back up, then stall out again. If I keep backing off the throttle I can find a spot where it runs 'normally' without stalling.
Concern: At higher speeds, when the throttle is in the spot where the engine rpm matches the road speed (it's neither making power nor engine braking) I get this LOUD metallic chattering noise. Is this normal for Chinese 2 stroke engines?
Some things to consider:
E85. I live in Iowa and ethanol mix is all we can get. I am running the 'premium' grade in it.
I've read that E85 should be mixed with ester based 2 cycle oil. This will be something I'll have to order order off the internet. In my small town, they've never even heard of such. For now, I'm just using the stuff I find locally.
I permatex'd the carb onto the intake. Like I guess most people I was getting a lot of extra air in there so that issue is fixed (I hope).
I'm running whatever the stock jets are. I have this innate fear of putting my carburetor parts under the drill press. I've also read that E85 doesn't produce the same power as non booze flavored gas. I've also read that it runs hotter. This would seem to explain why my spark plug boot has started to... oh... melt.
Thanks in advance.
Thanks in advance.
