I was lucky enough to find a Honda GXH 50 on ebay a guy bought and never put oil in it or fired it up for $230. Put a Qmatic transmission on it cost $299 and very powerful. If I ever see one at that price again I will buy it.
That could be fixed by putting the clutch on a jack shaft, could even slow it down some to kick the clutch in at higher rpm's...............CurtSorry if I added too much complexity. But, I have an engine that has crankshaft short length and is only good for a pulley or a gear. A clutch needs more length. Doing research for a non-kit and getting specs on items and see if compatible before you buy anything is important. I don't want to have others make a similar mistake. Models numbers for engines have options for versions, this is where I erred. Still a lot of the parts of this engine are good to use on another engine I have, or sell it working as is to recoup.
True, it is just so much is already built for gearing down and the room to fit it to make changes is difficult. I'll look at that option again. Another way was just push and go (no idle).... had a few motor bikes like that.That could be fixed by putting the clutch on a jack shaft, could even slow it down some to kick the clutch in at higher rpm's...............Curt
