Woodruff key No.# size
Legwon
does anyone know what Number size the woodruff key for chinadolls are?
looking for buy some replacements from Fastenal, but not sure what number they are.........
I've seen 3 different sizes depending on which factory the motor came from. On the plus side, all 4 keys in any motor I've seen are the same size.
Maybe this will help;
Harbor Frieght has an 80 piece woodruff key set for about 8.00USD.
Good luck!
I hadn't checked the HF sets to see if they have the size we need, or if they have at least 4 in the set, but that would be a cheap way to be sure you got a few spares...
It seems likely that some vendors might stock that part too...
Just to mention; The proper key will be sized in metric, and must fit in the keyway and sprocket snugly. No glue or other goop is needed.
With patience, you can file a larger key to fit. Any play must be avoided as it will lead to damage of the keyways, or shearing of the key.
As I learned on this site, "pinging" of the key could be necessary to assure that it will stay in place.
Let us know what you figure out.
Think I'll just pull one and measure it, and the slot.
Most of mine are same size.
However, crassius, you do have a point in different sizes. Got a Zoom engine for someone that wanted one installed. Noticed that the crank keys were thicker than the drive keys. Don't think they were any bigger though. Just thicker.
Basically what you don't want is a loose fitting key, it should be snug and fairly tight fitting, any play here will wear out the slot in the crank or the gear, or whatever the key is supposed to hold in place. You could file one to fit but I would never use one that's too small or that's loose enough to drop right in. It's not the key I'd be worried about messing up here, it's the slot on the crank or clutch shaft you don't want to mess up.
well so much for that plan.
i dont know if its company wide or store only ...
but Fastenal only sells to business' now
No Personal Sales, No Cash Sales
guess ill have to get something from online somewhere else .......
