genesis gs29, 29"
Fluxx
This is the bike I'm looking to mount on, any details I need look at?
I just built my old kit onto that bike for a friend of mine and it was very difficult. I had to build my own front mounting bracket for it and I bought a 2"exhaust clamp with the bracket as well . Sick bike parts sells one that might work for you though. Also had to cut the seat post mount down as far as I could take it. And the carburator won't fit in the frame so I cut the intake in half and ground the edge on the half that attatches to the motor into a cone shape to allow better fuel flow and I attached them with a clear rubber hose and hose clamps to allow it to sit outside the frame and zip tied it so its pretty solid. Or you could look for an offset intake to bring it outside the frame. Also you must space the rear of the frame out or else your drive chain will cut through it! And I would recommend a sprocket hub adapter otherwise you're only going to get 6 bolts in your sprocket unless you remove some spokes
Good luck!!
