Hey guys so here is the full story made short.
Bought a kit and installed it then after breaking in I over tightened the head bolt and messed up the lower engine case.
I bought a new lower engine from thatsdax.com but it was a different crank arm size so it would lock up.
then I got a new upper engine to fit the longer crank arm and the correct piston as well so it rotates freely now.
The metal wheels inside the lower engine have nicks in the metal from trying to get the wrong piston to start in the engine.
I sanded the head (where the spark plug goes) down so it was perfectly level, since it was a little warped.
Replaced the CDI and Spark Plug.
Then I replaced the magneto even though I had spark.
as you will see in the video I rigged the bike up so I could use a drill to rig up a Pull start kinda deal. While doing this at first I got a few shots of Fire out of the open Exhaust hole. So I opened the choke a little to see if it would help and twisted the throttled But it didon't shoot fire again or start up.
Here is the video so you can see and hear it and maybe it'll make it easier for you to help
https://youtu.be/cJ-JEMiey4E
