cannonball2
I finally found an explanation of when the stock CG ignition fires. According to the Grubee site its 15 degrees BTDC. That's conservative for fixed timing, up to 28 degrees works for hand started stuff. So I removed the rotor marked the keys center and filed about a 1/16 on either side of center for advance/retard.
Naturally I went for the full advance expecting the engine to wake up a bit, not so strangely.
I then went for the retarded position expecting a much improved idle and low speed running but a sagging midrange and top. Amazingly the whole range improved! Good bottom end, midrange, and the top reved out better than it usually does.
So The only conclusion I can draw is there is TOO much initial advance in the CDI itself, the key way in either the crank or rotor was wrongly machined/positioned, the rotor is magnetized backwards, and last I just don't know. And I do have the rotor on correctly
I wish some one else with a stock engine would give this a try and see if this is common or just isolated to my engine. The results supprised me.
