Not trying to hate on anyone, but welding the gear to the crank is a last-ditch fix to keep a wrecked crank going.
Better to fix it before it gets that bad in my opinion.
And to the OP.
If I understand you right, the key moving is what messed you up?
I have used a tiny drop of glue to hold it in place on a tight assembly...but be careful in case you ever have to work on it again.
Just a TINY DROP will do the trick to hold a loose key secure.
If it moves, stop and re-do until the gear seats correctly.
Keep in mind you may have to file the key so the gear will slide over it as well as getting it to fit the slot....
Sounds like you're close so just keep at it.
All the headaches fade when you go for a ride....
if you need the proper size woodruff key just pm me you adresss and i ship you one free as i ordered a dozen or more from mcmaster and wouldnt have a problem helping a fellow biker out....sum one was kind enuff to give me the link on this site to the proper sized key....thanks again and just lemme know.I dont understand what the big deal was.
