Did you put the chain too tight? It needs a little slack!
K, i will do the intro thing....its a 2t, plug is a B5hs...plug looks good, nice mocha brown, not wet nor blk. Choke yes....wont stay running with choke on.Is it a 2 stroke? What brand and heat range spark plug are you using. What ratio is your fuel mix? Do you know how your choke operates. Was the engine running good when you got it? Might also be good to go to the introduce yourself forum and tell everyone about yourself and your MB. More info. makes it easier to help you.
