too much gas?
aarcher30
my bike has about 30 miles on it, its runs fine but when I go up long hills when I get to the top it takes off and revs super high if I pull in the clutch? any ideas?
On the contrary; sounds like too much air: you're lean. Probably an air-leak exacerbated by heat. What color is your plug?
not enough info
you could be too rich at other times with idle screw turned in almost all the way to get it to idle, then emptying the bowl uphill makes you run leaner for a while - this you would fix by dropping the needle down a notch, then readjusting idle screw
you could have slow fuel flow and going lean because the bowl gets emptied
you could have a float sticking closed at uphill angles
air leak would happen at times other than just uphill runs, so I doubt that is it
idle screw is out about 4 turns, I have a good idle AND REV, I looked at it and dee d de, the cap came off of the throttle on the motor , screwed that on-- perfect, now I got another question, everything on my engine is stock, what after market parts should I get like spark plug and air filter?
One of the best upgrades from a stock kit you can get is an expansion chamber exhaust pipe. You will notice the difference. Also, if you only have 30 miles on your engine it's not broken in yet.
