one way to get rid of that "ting ting ting" sound is to put a layer of rtv on the outside of the bell and everywhere else except the contact surface, that'll dampen out that ringing sound effectively, just do it after the last ride for the day so it has enough time to cure and clean the surfaces you plan on applying it so it'll stick good.
Another trick that works is get a can of that "flex seal" stuff and spray it on the outside of the bell, and on the inside of your clutch cover plates to dampen out even more noise.
It only needs to be about 1/16" thick or so to work.
