Rack mount. Either chain or friction drive is an option. There's always the electric route too. Hub motors and batteries might be an alternative to internal combustion.I used a piece of cardboard cut to the dimensions listed on bikeberry of 8.5 X 7 and was able to find it fit but it was very tight. if not in frame what would be suggested?
A slant plug head might give you the frame clearance needed.Tom
What are you going to do about a carburetor? You're going to have to resort to some kind of offset intake manifold. Some vendors sell them of if you have metal working skills and a welder you could make your own. There have even been a few who have used rubber hose as a manifold although that is an iffy prospect. Securing the carburetor from vibration is just one problem with hose.Well i got the motor and its tight but it fits
http://motorbicycling.com/attachment.php?attachmentid=70699&stc=1&d=1402341817
now to get everything on the bike so i can get to riding.
The front mount looks okay and I'm sure you know it will need bolts to span the width of the down tube. We can't see the rear mount. How does it fit the seat tube?
If you have spark plug clearance issues there are 'shorty' plugs that will work. I've used Autolite #2976 with good results in tight fit builds. The cylinder head can also be rotated 180 degrees to slant the plug away from obstructions.
Good work so far. Keep us posted and good luck.
I enhanced your photo so others can see the details better. Hope you don't mind.
