66 cc piston>>>
weight it
cut out reed window
weigh it
balance piston
remove lower ring.
install a 48cc wrist pin>>>
first tap M4 threads into oil holes
Install wrist pin with brand new M4 set screws everytime piston is removed. must use new set screws for good lock. can also be backed by m4 nut but im not doing that.
------------done
in doing that 7 grams can be shed from piston assembly. you will notice if u hang the piston 0.2 grams will tilt it off from level. so i hang mine just to see w my eye its level and balanced after a scale balance.
solid wrist pin and lighter weight..... i have 10 minutes on mine so far. time will tell.....wish me luck!
weight it
cut out reed window
weigh it
balance piston
remove lower ring.
------------done
