Just got the new DAX RT carb and need to install the throttle cable in the carb. No directions to go by. I don't know what's fragile in there. Any advice greatly appreciated?
At the base where it goes on to the intake make sure your gasket is on all the way also make sure that your carb is on all the way. it sounds like you may have a air leak and from my experience that is the easiest place to get it. Also check that your cable is adjusted right and not what is holding the throttle at high idle.ok, I've gotten the DAX RT carb installed and took it on a test run of a little over a mile. I'm running a Grubee GT5 66/80cc angle fire using opti2 oil mixed at 100:1. For about the last 400 miles I've been running a CNS v2 carb with the tube disconnected between the bowl and air filter. All else is as it was shipped to me. Performance has not been bad with the CNS. Idled great, decent acceleration, seemed to 4 stroke quite a bit getting close to WOT. Hated the choke lever on the handlebars.
DAX RT Carb: Has high idle when the motor is cranked. Turned idle screw as far out as it would go. Still idles high. Ran it to see performance. When stopping at lights, the motor initially idles great. Gradually the idle builds. Revving the throttle does not make it idle down. By the time the light changes the motor is revving enough that i'm concerned. This process repeats at every stop of more than a few moments. The motor isn't putting out as much power as it did with the CNS. Hills I struggled over with the CNS the RT can't seem to get me over. Acceleration is slightly weaker than the CNS. Not much, but noticeable. Didn't have enough level ground to get it much past 3/4 throttle. Seemed nice. Not as much 4 stroking as the CNS. Will get to try WOT tomorrow. What I liked about the DAX RT better is that the throttle cable slides extremely smooth. Not having to deal with the CNS choke cable and handle bar lever makes for a much better look to me. Hopefully I'll like WOT tomorrow. Throttle response is better on the DAX. I like having the option of trading out the jets that came with it. It comes with a #70, #75, and a #80. The #75 is pre-installed. I'm going to switch to the #70 after trying this for a while. I'll save judgement on the DAX RT until I've run it a while and/or tried a different jet.
any ideas on better throttle response?Just installed my rt carb and it works great...but how do i know which of the five jets to use?...I have the one that was already installed in the carb..no complaints!..But there are five more and i am wondering if i can get more out of a different jet?![]()
