rogergendron1
hi everyone, i have a grubee gt5 that needs rebuilding and i have read that the grubee gt5 66cc jug has a differant port map than the standard pk80 or dax balanced motor.
my question is can i run a pk80 jug on a grubee gt5 ?
i know the pistons are differant as in the location of the wrist pin hole is lower on the grubee gt5 motor or is it higher lol i forget..... any way are all the jugs the same and the grubee just uses a differant stroke crank arm and thinner base gasket and higher wristpin hole than others to achive the same port timing or are the jugs differant as well ?
for instance i know the grub33 gt5 has a differant piston and stroke than my dax does
dax has a 110mm con rod and is 85mm hole to hole i think
and the grubee is 100mm and 83mm hole to hole ?? i am unshure here.
can i use a pk 80 jug on a grubee with some modifacation if i have to ?
for instance with a thicker base gasket and a differant piston ?
my dax has a 1.6mm base gasket and the grubee gt5 was far less like .5mm so right off the bat the dax has 1mm taller ports and the piston is differant also so w.t.f. ???
where can i get a grubee jug lol ? the only place i know of is arrow and they are all modded, i plan to save money and do the moddin and porting myself so spending 70$ on a grubee jug is out of the question ! all i can seem to find is pk80 type jugs for sale where can i get a stock grubee gt5 jug ?
or can i just use a pk80 jug and mod to get the correct port timing by raising or lowering the jug via gasket thickness and raising and lowering the piston via wrist pin location ?
the ports need to be fully open at BDC and the piston needs to come to the top of the jug for correct squish clearance at TDC, can i achive this with a pk 80 jug on my grubee gt5 motor using gaskets and piston swapping? or do i need a grubee gt5 jug ?
