Nice to see someone else building the $128 (now $134) gasbike kit. this is my first one ever - i bought two kits. I'm gonna have a bunch of questions for ya if you dont mind.
My current problem is with the sprocket and rag joint. the holes in the sprocket do NOT line up with the holes in the split metal rings. plus, I'm installing this on a genesis astra which has 48 spokes. So, I drew it up in CAD and I'm making my own rag joint connection. I went to home depot and bought some rubber to replace the rag - so I can drill my own holes. I was walking around home depot and the morons that work there couldn't point me to some thick rubber, so in the plumbing department I found a 4" rubber pipe coupler (that has hose clamps on both ends) for $8. I cut one side and layed it flat - used my template and cut / drilled it.
So, the arrow on the piston goes toward the exhaust, I'm told. can anyone tell me what the head bolts should be torqued to ?
Oh, and what are these PINS everyone is talking about ? the ones that I will break if Im not careful ? can anyone post a pic ?
how should I orient the piston ring gaps ? just opposite one another ?
cheers
