Hi everyone,
The actual thread on my bike is in the road nike section, but not thatnive given it the first tests.today, I could use some more specific help... so here I am.
I've got the bike done essentially, other than 2 vintage style stem mirrors for the handlebars, which should be here later this week. Today was the first test start, and overall it went quite well but I do have a few questions or concerns.
I was able to start the bike right up after about five turns of the pedal, after releasing the clutch (choke open). The bike seems to have plenty of power, it really does seem to move quite well and quite strong. However, I don't know that I've ever adjusted the idle on a 2 stroke motor and I'm not sure if I have the fuel mix too heavy or not or if there's something else to address.. here's what I'm noticing:
The bike idles quite rough, and if I release the throttle it will conk out within a few moments. When you're building up from a lower speed or hang your around a lower speed, you can definitely hear the engine either choking or aspirating a little here and there and sounds like the engine is pulsating slightly.
I haven't adjusted the idler screw at all yet other than just messing with it a little bit... trying to just open it and close it some and see what happens. If I close the choke on the carburetor, which is just the stock carburetor that came with the engine, it will run really slow and will stall out itselfv. I haven't noticed any fuel leaks so far other than when I was almost out of gas finally (I only put in 1/4 tank, and mixed one pack of Opti to one gal of gas today), I noticed that that last short piece of hose running from the back of the pancake fuel filter to the carburetor was leaking some right at the brass connection to the carburetor. I read that the fitting is actually 3/16th of an inch and not 1/4", so I will get another piece of fuel line from work tomorrow (3/16") and I will just heat up the other and to expand it and slide it over the 1/4" barb of the fuel filter.
Any suggestions on where to start? I don't know if that last connection of fuel line is causing the equivalent of an air or vacuum leak and if thats causing some problems, I don't know if it's that the air filter needs to be removed or replaced with something different or if I just need to mess around with the idler screw until I find a happy medium... or maybe something else?
When I'm actually just riding it, it really moves and seems to handle quite well.... I think it's just a matter of some sort of adjustment or some sort of tweaking to get it to run really well but I could certainly use some help those that would know. It's a blast to ride right now and I'm really enjoying it even with just trying it out today for the first time. Thanks in advance...
