Back to the electric thread. I'm still having back pain but I managed to put in a few hours in the shop yesterday. I'm paying for it today, but I did get the new rear put together for my trike/scooter. I'm not sure how they will play out but here is what I have.
First of all it begins with a wooden platform. I made mine out of a piece of 1"X10" pine. Since that stuff splits, I bolted a 1/2" piece of plywood to it. Then on the edges where the wheels will attach I bolted an angle iron. So the axle won't cause a split in the wooden platform.
Then I measured 3" from the rear of the wooden platform and drew both a horizontal line and then one vertically line in the dead center of the piece of wood.
I wanted to use one continuous axle. but I didn't have a crown bolt long enough, so I went for two crown bolts, one for each wheel.
I found some pieces of fence stretcher bars which I use for general purpose metal. The fence stretcher is used in chain link fences for just what it sounds like. They are about a half in wide and three, four, and six feet long. I buy the short ones and cut them off as needed. I also reuse them over and over so usually I have some short ones laying around. In this case I found sex of them between two and four inches. I used them to make straps for attaching the axles after I determined they were straight. For that I used the horizontal line i had drawn previously. I used two straps to wedge each axle against the wood and one to wedge it against the metal frame on the edge. I'm pretty sure they are secure.
Moving along to the wheels. Another benefit of working with thrift store junk is that I have lots of old wheels laying about. So I began with a front wheel. Once the short axle is removed, if you are lucky and careful, there will be a bearing set in a cage on each end. Then you need to drill the threads out of (4) 3/8" axle bolt. They make great bearing holders and spacers. The drilled 3/8" axle bolt slides on first against the metal from of the platform. Then the caged bearings. Then grease and the wheel. on the outside of the wheel you need the bearing cage, another drilled axle bolt finally two 3/8" bolts to make a lock nut for the axle assembly.
Repeat this for the second side and you have a trike rear end.
I haven't gotten to the final step yet but I can outline it for you.
To Attach It To the Bike.
First you drill (3) 3/8" holes along the vertical line.
Then you cut three pieces of the angle iron the width of the platform.
Then you simply use some more scraps to make a plate to secure each of the reinforcement pieces through the holes you drill in the platform and also to the bottom of the bike frame. You want to wedge them tight.
That bolted assembly should look like this. The head of the bolt then a piece of metal over the frame of the bike. .. then the lower frame of the bike... then the wooden platform,.. then the full metal reinforcing L frame piece... then two bolts to lock it.
Now I haven't tested the assembly yet, since I haven't finished it, but I have tested each component separately and it all seems to work.
"PLEASE BE CAREFUL IF YOU FOLLOW THESE INSTRUCTIONS AND YOU DO SO AT YOUR OWN RISK..." Trust me pay attention to weight distribution.
