So "Eagle Butt" just won't start.
The following things are different from this build to the last build that could have an effect on it starting:
New tank (new as in different)
New petcock (new as in different)
new gas line
New throttle and kill switch
I made the following changes and then tested it to see if the engine would start after each change.
First I shortened the gas line to make it all one downward shot, no peaks and valleys.
i checked to see if the tank was able to suck in air by blowing into the vent hole.
![laff laff laff](https://motorbicycling.com/images/smilies/Laff.gif)
No problems there but I'm pretty sure I'm a little lightheaded. lol. jk
The petcock is clearly allowing gas to flow into the line, I can see it flowing and if I remove the gas line from the carb, gas flows out easy with a nice steady even flow. conclusion: petcock works.
I switched the wires from the throttle to the CDI. with the idea that MAYBE the wires I have in my throttle are not the same as stock.
No change
I disconnected the kill wire. NO change.
So all of these changes make me think that the issue is elsewhere. Spark plug or in the carb. I've had the carb bowl apart and cleaned the gunk out of it.
Over all I pedaled Eagle Butt around the hood, my neighbor, who happens to be my ward's city Councillor stopped me to talk to me about it. He rides a Chinese Scooter about 50% of the time. The rest of the time he drives a pick up. Nice guy but a politician through and through.
When I'm testing the bike I pedal across the street to the Public Works parking lot and up their steep parking lot to the top of the hill then pedal like **** to get up to speed before I run out of space and pop the clutch, that is usually enough to get it to turn over. And used to be enough to get her to start. There were a few trucks parks in the lot, usually at this time of night no one is in them, but there was one dude in his truck, his head snapped towards me when he heard the engine turn over. This is the general reaction I get when I'm riding this thing around.
It turns over, clearly has compression, and is turning over but will not continue running once I pull in the clutch again, even if I pedal down the street. it's as if I'm holding down the kill switch. but even with the kill disconnected no joy. Any ideas?
I'm thinking I should get a new spark plug and wire and maybe tear down the carb or buy a new one.
At this point I think I'm going to make a vinyl decal for the side of the engine that says "Tease."
![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
