mew905
Disassembled my bike, replaced all the 6202 bearings with SKF ones, drilled the piston sides (where the transfers are, so no port timing change, just two tiny holes), and the crank (pics below). After reassembling I fixed a massive compression leak, replaced all the gaskets with SBP copper gaskets, and installed the new bolts from SBP. Permetex'd the head to run with no gasket again, aaaaaaand it runs like garbage. Sputtering everywhere, no power, every 5-15 seconds you hear a "poof" from the exhaust. Did I screw up the crank job? It's a solid crank, not one of those fancy ones with the removable weight. When I drilled it, I drilled ALL the way through, I didnt just drill one side, flip it, and drill the opposite side. Maybe I need to jet down? Maybe it's being flooded with way too much gas? It runs rougher than before so I'm not sure.
Split crank, brand new industrial SKF bearings
Pre-drilled crank
During drilling
After the job is done
Pre-drilled crank
During drilling
