Mr.GhettoRig
so After scratching my head long enough I've finally decided to ask for help.
I'm setting up a belt drive for my electra build (http://motorbicycling.com/showthread.php?p=446984#post446984) with a suicide lever that engages and disengages the belt.
My first question is about the gear ratio, I wanted to make sure that the pulleys I have now are adequate enough to get the bike moving. diameters are...
Engine: 2.75
Jackshaft-in: 3.625
Jackshaft-out: 3.5
Whizzer sheave: 15
wheels: 26
Also I'll be generous and say my engine tops out at about 4,000 RPM.. (5hp briggs with shaved eyebrows, cleaned ports, header, and a tec 5hp carb. I believe they are normally governed down to 3,500 stock.)
according to this calculator ( http://www.fasttrackraceway.com/calc/index.php ) I have a final ratio of 5.65. but I dont exactly know what that means? Is that acceptable?
And my second question is how tight does the belt need to be on the engine to jack shaft during idle and drive? I plan on using a flat idler pulley on the bottom (slack) side of the belt, as I read on here that requires less tension to get the drive to work. I'm just unsure of how much slack to give the belt during idle, and how far up to move the idler pulley for belt tension.
This is new to me so any and all help is appreciated. Thanks in advance.
Engine: 2.75
Jackshaft-in: 3.625
Jackshaft-out: 3.5
Whizzer sheave: 15
wheels: 26
