the basics for a vibration-free bike is keeping everything tight. anything that can move will cause an oscillation.
when i put my motor on magrider's bike i tested it with a stock gas tank loosely mounted and the bike vibrated like crazy.
tightened up (or removed completely) and it went away. even custom, in frame tanks can cause a vibration. the tank is one place where rubber or silicone or some other soft mounts actually help, but it still needs to be tight.
a simple test is lean your knee into the tank when the vibes start, and see if they go away.
motor mounts should be secure as possible. no rubber mounting, and welded brackets to the frame if possible.
anything hanging, like an exhaust pipe will transmit vibrations, too.
loose chains or poor chain alignment, same thing.
racing a shaky bike at full throttle for 10+ laps is no fun. it's rough on the bike, and tires you out.
33 ain't gonna cut it in the big leagues.
you'd have a hard time competing in the stock class...
do some research on what the other guys are doing to figure out what you're missing.
