Routine (rebuild) Maintanance
ran49
186
So.In.
Just wondering if any of you guys ever change rings and wrist pin bearing on any schedule or just run it until a problem becomes obvious.I have about 1400 mi. on my Dax 70cc.and it run as good as new.I have an extra set of rings and a new bearing and would much rather do this work in the winter while I'm not riding it than in the summer.I guess you can do a compression test but is there any way to judge the state of the bearing.Thanks Ron
jasonh
1,590
Longmont, CO
If you pull the cylinder off, I think you can check the bearing for excess play by wiggling the piston around. I'm not 100% sure but I believe it should only move back and forth in one direction.
