Found the perfect solution to your problem:
http://motorbicycling.com/attachment.php?attachmentid=58701&stc=1&d=1366431055
Theoretically, it takes approximately 745 Watts to produce 1 horsepower or 1 horsepower to produce 745 Watts. Watts = Amps X Volts. You need 25 Amps at 12 volts which equals 300 Watts. So, theoretically, you'd need a more than a 1/2 horsepower to produce your 300 Watts. You also have to figure inefficiencies of converting the 12 volts to 48 volts, drag, tire resistance, etc.
How do you plan to get an additional 1/2 to 1 horsepower? To create energy, you have to expend energy - be it peddling or gas engine. I doubt you'd be able to sustain pedaling enough to generate 1/2 to 1 horsepower of energy. Just bolting a alternator onto your bike isn't going to do the job - it's just going to create resistance and deplete the batteries - nothing comes free.
Start-up is the killer of batteries and uses the most power. You could increase your range by pedal starting or using the gas engine and then when reaching cruising speed, use the electric motor.
Or you could use the gas motor to assist the electric motor to get an extended range. Another possibility would be to buy a 48 Volt hub motor for the front wheel to generate electricity, but would have to use the gas engine to generate the 1/2 to 1 horsepower, necessary to charge the batteries. Yes, hub motors generate electricity - just search YouTube or the Internet. It has to be a non-geared hub motor.
Good Luck,
Chris
AKA: BigBlue
Good Luck,
Chris
AKA: BigBlue
