External adjustment of the primary clutch spring
Good evening guys,
There is a way to adjust the primary clutch spring externally. So far we have had 4 engines in-house...one of them had a REALLY tight clutch. Tight like others have said they felt like the clutch handle was going to break!
Before I go into a long diatribe with photos and all, I was wondering if this is common knowledge?
I couldn't find the info anywhere in the archives.
Jim
Not sure what you mean Jim, care to elaborate?
Definitely...I discovered this when I completely disassembled an engine... I didn't think anything of it at the time. I got in two more engine kits, and we were checking the actuators for fitment, one was REALLY tight!!! I then remembered how the clutch is configured from the disassembly I had done earlier. We adjusted the primary spring and had a normal clutch!
Jim
If this info has been missing,
I'll try to put together a description with photos tomorrow.
I usually tend to think that my new found discovery has already been around the block a hundred times.;) Maybe this newbie has found something that will help others.(^)
Jim
The only adjustment I know of is adjusting the flower nut. Definitely would like some more info.
Or he's in the shipping/receiving/recreation/TV/coffee room packing up my actuator. :D
Ted
Yes!
And in fact your actuator has been shipped.(^)
Thanks again for your order.
I finally took a bunch of pictures with my crappy camera...I've got to get a new one!
I'll have a description ready here shortly...stay tuned!:D
Jim
Alrighty then,
I've attached some photos...my camera is really crappy but you'll be able to see how the thing works.
Basically the outer diameter of the main jackshaft has a fine thread. There is a collar that is threaded internally. Tightening or loosening the collar sets the preload for the primary clutch spring.
They used a high rate spring...which means that it is really stiff in short travel increments. Tighten the collar one turn and it makes a huge difference in the clutch pressure.
We had one engine that had a crazy stiff clutch. I've read posts where people have actually broken thier clutch handles. Our actuator knocked most of the stiffness away, but still I knew something wasn't right, as our other engines were fine, just like the first that we put together for a customer. We backed off of the collar 3 turns and the clutch was normal.
I have to emphasize that you do want back this collar off too far. It's impossible to totally unscrew it from the shaft, (while in the engine), but you don't want to put the assembly in a bind either.
The bottom line guys...Don't use this info to try and achieve a totally perfect clutch lever pull. The actuator is junk from the factory, and no amount of adjustment is going to totally negate the effect of the poor design of the original actuator. If you have broken a clutch lever, or you feel like it may break...give this a try! Even with the factory actuator your clutch should not be this tight!!!
Remove the clutch cable stanchion from the engine.
Remove the drive chain.
Have a helper hold in the clutch lever; or you can, of course, use the lock feature on the handle if it works well enough to fully disengage the clutch.
Through this hole, (where the cable stanchion mounts), you can insert a punch, 3/16" diameter or less, and catch one of the slots that has been milled into the threaded, (adjustable), collar. Hold the punch firmly.
Use a pair of channel locks to turn the sprocket in the same direction as if the engine were running. In other words countercockwse from this side of the engine.
Try one turn at a time...be certain to freewheel the shaft to ensure that nothing is binding.
Jim
I am gonna try this my clutch is ready to go .
When are the American clutch pucks gonna be ready for sale?
I just used to grease that hole
I never thought to adjust it. LOL.
