Hello, I have a grubee gt 5 it slowly started to run worse and worse...Its got about 3400 abused miles on it and still has 120psi compression,,never had a problem with this motor so I would like to fix ....Started checking for air leaks and noticed smoke coming from the clutch side output shaft...So im thinking bearing seal ..Ive done them on mopeds a few times without a lot of hassel ,,,just get the old one out and replace... Not sure if they are the same on these motors ??? Any tricks or things I should know before hand???
I see one site might have the part but no description on this???looks like the seals on the right??
http://speeddemon.ca/motorized-bicycles/parts/gasket-set-49cc.html
Anyone know where I can just buys the seals ???
Any help would be great THANK YOU
