DanielMaia
Hi there guys,
Im having some problems on a 4 stroke engine kit.
The first problem was burn completely the clutch, after 5 miles of use.
It uses a 11T front sprocket. I thought it was because the 40T sprocket, changed for 44T sprocket, bought a new clutch kit on a local store, went for a ride, and it seems the clutch is spinning a lot..in a little hill, even with max throttle, the clutch doesnt "stick" on at all..
Im not heavy (around 150 pounds), the bicycle has about 60 pounds...
I was thinking in the carburetor...if the carb is not tuned properly, it may not accelerate as it should, and the clutch springs does not expand..
What you guys think?
