Had a spare engine lying around and a spare beach cruiser so decided to build another mb. My original problem was that the down tube was oversized. I know how to mount on these type of tubes, but just got a welder and wanted to fab something. Also swapped the stock bolt studs with bolts going into the motor itself. I basically copied the mount sold on gasbike.net (http://www.gasbike.net/alum-bike-frame-gt-2-a.html)
Took a total of about 45 minutes to cut, shape and weld the piece in place. I used an angle grinder and the welder.
I went over all the welds to reinforce them after the pic was taken, and am VERY confident that the frame will break well before the mount (take a look at those horrible welds on the frame....eek!)
As for:
chain clearance, perfect
How solid is it, rock solid
Air filter/Throttle cable clearance....BARELY enough room. If i was to do it over again i would make it about half as long.
As for:
