I dremelled the square corners off of the teeth to allow the chain to roll off of the sprocket smoother. Just break the edge a little and you can file it if you don't have a dremel.
Yeah, check the chain alignment (front and rear sprockets must be in line and on the same plane so there is no torsion on the chain), and check chain tension. I had the same problem recently and it was chain alignment. I am using 415 chain, which came stock from the undisclosed location of the Chinese bike chain factory.Yeah, check the chain alignment (front and rear sprockets must be in line and on the same plane so there is no torsion on the chain), and check chain tension. I had the same problem recently and it was chain alignment. I am using 415 chain, which came stock from the undisclosed location of the Chinese bike chain factory.
