Its the same hub, with coaster brake. THe Sturmey archer site does not show the driver sprocket. I assure you, the link at SJS and Niagara are the same hub model. src-3 = ts srf-3.
You are lucky if you can find a trike hub at all.
Why cant you use coaster brake version? Do you really plan on your engine spinning backwards? Ive yet to see an engine spin backwards and apply the brakes on a coaster hub.....
If there is some other reason, just take out the pucks....
The only 3-speed hub that is different that the sram, sturmey-3, or inter-3. is a sturmey s3x fixed gear hub. THe advantage of the fixed gear hub jack-shaft is that you can roll-start a china girl through the hub.
