Tecumseh AH600 carb?
dracothered
I am wondering how good the stock carb is on a Tecumseh AH600 2 stroker? If the stock carbs are good enough, which type would be the better one (Float or Diaphragm)?
it depends on how your motor is in the frame if the carb will be level or mostly level float will work but if it has a angle or you are going to race with alot of cornering Diaphragm is better
Thanks, are the ones used on the Tecumseh's good?
that i cant help with because i dont know the motor or the carb in question but i say put it together and see how she runs
