Check this out another snowblower build http://motorbicycling.com/showthread.php?t=42400................Curt
Cool look...Check this out another snowblower build http://motorbicycling.com/showthread.php?t=42400................Curt
Just for your information Bud the engine in the pictures is a Jacobsen itll be 3-5hp. Im building a bike now that uses the same motor, its my second build with a jacobsen.Ok, I just bought this little beauty and now I'm looking for info on one of these while I wait for it to come. Have any of you seen one or had one of these engines?
This is suppose to be the model:
Tecumseh model 9B28B518830 2hp horizontal engine
I can't tell yet by the pictures, if the carb could be move some or not.
The AV 520 has a square head the jacobsen as youll notice has a round head and if ya peek inside youll find a very HIGH domed piston redline is 4500rpm stock on the jacobsen. I run mine @ 50:1 using a synthetic 2 smoker oilThat engine is an AV520 series Tecumseh, they came with different trim over the years.
The spec sheet says 24:1 on oil mix.
Because it is a reed valve 2 stroke with a diaphragm carburetor it will operate in any orientation as long as the fuel keeps flowing to the carburetor.
It would be a bad idea to re-locate the carburetor on that type of engine. You could lean the cylinder forward parallel to the front frame tube very easily.
Heck, you could mount it upside down with the carburetor straight up if you wanted to.
AV520 Spec Sheet
AV520 Blueprint
Good luck with your project.
B.
This engine got put on hold for a Tecumseh AH600 which has a better setup for my build.Drac did ya ever finish this build?
