Since I found a few hairline cracks on my 2002 Cranbrook after about 300 miles with my 66cc China Girl, the hunt was on for a new frame. I liked the look of a motor in a cruiser frame and wanted an older American steel frame, but around here those seem to be going for pretty much their weight in gold. At least on Craigslist, I think next time I will put in some footwork and visit the local salvage yards.
Anyways, a 1988 Schwinn Heavy-Duti turned up on Craigslist, which I got for $40. It is not a Giant frame (I assume, since it does not have a G serial number stamped on the rear dropout, but does have a serial number on the bottom bracket that starts with "LV" and the number 1288 on the headbadge, so just assume it is 1988 and not 1978...)
Still, seems much more solid than my Cranny did, so the build is a go!
This is what she looked like when I got her home:
I took about a week of using paint stripper, a brass wire wheel, and wet sanding to get her down to the bare metal, then cleared the frame with Rustoleum Clear Engine Enamel. It is supposedly oil and gas resistant, so we will see how it holds up.
I found that I needed a new front motor mount, so made one out of the mounting flange that came with my BGF RB80 kit and a piece of the seatpost from the Cranny. I press fit them together, then had a local muffler shop weld it up for $20. Nice and sturdy!
I also went ahead and got a shorter crank from my LBS since I anticipate going with a centrifugal clutch soon. It takes getting used to, but so far not too bad.
Other than having to get the front motor mount welded, everything else swapped over smoothly from the Cranny, woohoo! Well, except for the Crow Cycle center stand. It bolts right where the integrated Schwinn kickstand is, and since I did not want to cut the kickstand mount, I am going to have to get a rear axle stand instead. I really like center stands...
And I am going to need a new layback seatpost too, since my Kip Harley post is made for a 1" seat post and this new one is 22.2cm (7/8"?).
So got everything buttoned up last night and went for a maiden run today. She ran GREAT!!! No surprises, nothing shook loose, no complaints. It was nice to be back in the saddle after being down for about a month.
I still need to polish her up and make the side covers to go over the Jaguar CDI and coil since the opening is a little larger and on the Cranny so my old covers do not fit right. I also want to either swap the black forks for chrome, or just strip and clear the ones I have.
So here is where she is at now:
To do:
![](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F9592539%2FBicycle%2F1988_Schwinn_HD%2F1988_Schwinn_rusty.jpg&hash=168b952140dcad81f680885889591e10)
![](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F9592539%2FBicycle%2F1988_Schwinn_HD%2FInitial%2520Assembly%2FAssembled_left.jpg&hash=6767f4a95f8a202229b4e0908c85d7fc)
![](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F9592539%2FBicycle%2F1988_Schwinn_HD%2FInitial%2520Assembly%2FAssembled_left_front.jpg&hash=132e09e1d60042fad2188f38c59a2a8d)
![](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F9592539%2FBicycle%2F1988_Schwinn_HD%2FInitial%2520Assembly%2FAssembled_right_angle.jpg&hash=69faa8c1f72c37018a98bd8d2d7e6801)
![](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F9592539%2FBicycle%2F1988_Schwinn_HD%2FInitial%2520Assembly%2FAssembled_right.jpg&hash=c920f81180f50ae2fcce847fbecc3bef)
- 1988 Schwinn HD frame
- Weinmann AS7X wheels with 12 gauge spokes
- BGF RB80 66cc motor
- NT carb with 68 jet and needle at leanest setting
- Puch 70cc hi hi head with one head gasket
- Pirate Cycles hub adapter and 36 tooth sprocket
- Jaguar CDI and coil
- NGK b7hs sparkplug
- Speed-Demon exhaust
- Beehive springer front end
- SBP bolts and studs
- SBP HD air filter
- #41 Tsubaki chain
- Skipu chain tensioner
- Al.Fisherman clutch roller
- Wald rear rack
- Short single piece crank
To do:
- Lace up 90mm Sturmey-Archer drum brake (purchased)
- Buy 22.2mm layback seat post
- Make new CDI covers
- Buy old-style construction worker lunchbox for toolbox on rear rack
