Greybeard
I've noticed a few aftermarket analog mini tachs available for motorcycles.
They range from 8k to 10k units, are in the 2-2.5" size, and designed for V twins.
All of our two strokes, and probably many of the 4 strokes we use fire the plug every revolution. On my Honda one's a waste spark. That's how often a large twin fires as well.
The tachs require a "ground" signal to operate, and we don't have that, but we do have enough "signal" to operate some electronics without killing our ignitions or the mini digital tachs wouldn't work.
So here is the question. Can we not build a circuit with a transistor, where the transistor switch is going to ground. I don't know what the signal voltage from the CDI would be, but I'm sure a few resistors could drop it to where it wouldn't pop the transistor. Then, a 12 volt supply would need to be established to operate the tach. ??
