biknut
This is a short video I made showing china girl crankshaft runout.
http://www.youtube.com/watch?v=CZv_sVNC_q0
So how do you fix that runout?
Sand it, grind it, bend it?
JB weld?
Do tell!
You force it back into alignment , with a press or a hammer I've seen both used . Hope that helps . DanSo how do you fix that runout?
JB weld?
Do tell!
do you know how to balance a crank?
do you sell a balanced and trued crank?
liveforphysics, can you sell me a balanced crank for the chinese motors?
Biknut,
Look forward to your dedication on truing HT crankshafts.
In my research of the subject, I've found that most posts recommended using machinist V-Blocks, rather than a lathe. The V-blocks are more accurate than a lathe which requires tuning and adjustments. I don't think you'll get a wood lathe near the accuracy of V-Blocks.
Here's a post to check if your centers are aligned. This might indicate how accurate your measurements are. About 2/3 down the page - shows using a 0.005 - 0.015 feeler gauge leaf to measure alignment:
http://www.mini-lathe.com/Mini_lathe/Tuning/tuning.htm
I am not a machinists or mechanic - Just my 2 cents.
Keep up the pursuit and I look forward to your continued journey.
Chris
AKA: BigBlue
Live,
Roller Block?
Is this what you mean?
http://motorbicycling.com/attachment.php?attachmentid=49183&stc=1&d=1340258759
Chris
AKA: BigBlue
Live,
Roller Block?
Chris
AKA: BigBlue
