That is a pretty slick idea (sprocket running off the outside of the primary drive chain). I just may use that on a future project just to do it!I think that the old "Iron Horse" brand 4 stroke antique washing machine motors meet that requirement.
You can reverse drive rotation with the preddy by driving a remote idler sprocket with the engine, and running a jackshaft sprocket against the OUTSIDE of the primary chain.
Well, you can do an inframe friction drive and get the look you desire. With the large roller, it worked very well on my first Preddy build.That is a pretty slick idea (sprocket running off the outside of the primary drive chain). I just may use that on a future project just to do it!
However I will stick with my CCW predy and just keep everything on the left side(not as I had envisioned).
from what I hear the toilet bowls in OZ do swirl to the left there in the land of Down UnderI don't know what this has to do with the discussion but on the local news tonight they reported that there was a tornado in eastern Colorado that was a "reverse rotation storm". They said the tornado was rotating backwards from what is usually seen in the northern hemisphere.
So, it made me wonder; If your engine runs counter-clockwise and you took it south, below the equator, would it run in reverse?
The old Cushman scooter motors are opposite of normal. They have the flywheel on the left and the clutch on the right.2door...rather not know....
Only motors that I am aware of that have a reverse rotation option are marine outboards for use in multiple motor setups
unless its a left hand drill bit they only cut spinning to the right/clockwiseI honestly thought all engines were CCW. Put a drill(bit) on the end of one and it should drill a hole.
