I think that the old "Iron Horse" brand 4 stroke antique washing machine motors meet that requirement.
You can reverse drive rotation with the preddy by driving a remote idler sprocket with the engine, and running a jackshaft sprocket against the OUTSIDE of the primary chain.
That is a pretty slick idea (sprocket running off the outside of the primary drive chain). I just may use that on a future project just to do it!
However I will stick with my CCW predy and just keep everything on the left side(not as I had envisioned).
I don't know what this has to do with the discussion but on the local news tonight they reported that there was a tornado in eastern Colorado that was a "reverse rotation storm". They said the tornado was rotating backwards from what is usually seen in the northern hemisphere.
So, it made me wonder; If your engine runs counter-clockwise and you took it south, below the equator, would it run in reverse?
2door...rather not know....
Only motors that I am aware of that have a reverse rotation option are marine outboards for use in multiple motor setups
I honestly thought all engines were CCW. Put a drill(bit) on the end of one and it should drill a hole.
