Chickenegg787
I had my first build running good and clean for about 2 months. Went to refuel as I have done multiple times by now, but either the ratio was off or I had to wrong oil as I was experimenting which combinations would run the best. Anyways, I was on my way to a camp out so I had a pretty heavy load with me and after about 18 min into my ride (luckily I was practically there) the engine started slowing down to the point where it shut off, and when I looked down to see what was wrong, visual flames were coming out of the exhaust. At this point it was shut off and I pedaled the rest of the way.
The next morning is my issue. I went to go see if the overheating damaged anything and this is where I am at. When I pedal to get momentum to turn over the engine, everything is smooth until i engage the clutch. What happens is, my rear tire completely stops rotating and I skid until I stop. I took off the clutch plate and looked at the sprocket. I was unable to turn the nut connected to it to the point where it rotates the whole gear along with the chain as you have to do to get the chain on. I went to tighten the nut and it just keeps spinning due to the limited thread...HELP! what's going on!?!?!? the clutch sprocket doesn't rotate at all!
