inexpensive gearbox and motor mount for 99cc predator build?
I want my next bike to be a predator build when I get the money together. the build would probably come along a lot faster if it were less expensive. I can get a qmatic gearbox with a motor mount for $300, which is probably a decent deal, I am just wondering if it can be done for less. is there any way I can obtain a gearbox and motor mount that will fit the 99cc predator for less than $300? lmk.
your only limited by the skills you have with the tools available and the size of your junkpile
you want the ease of a bolt togather kit then your going to have to pay what
the people who are selling it for as they put in the research to make the kit...
dont have a junkpile or any parts relating to a 4 stroke build, having never done one and only having used and worked on ht engines thus far. perhaps you could give me a more helpful answer than that.
does a predator use a 78mm clutch?
if it does then you can
better make sure that motor mount is drilled for the bolt pattern of the pred
designing parts and then making them is not something i can teach you over a computer its learned by watching and doing tons of researching and being able to see what your building in your mind complete and working and seeing that vision in a pile of odd parts on your workbench
This is what agk uses on their 99cc Predator race bike.
Shane came in 2nd gas bike and beat all the 5 HP Briggs bikes in
the Mid range class at the last race with this gearbox.
http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=2600&Category_Code=99cc
I found a motor mount for 25 bucks, and a gearbox on thatsdax for 40. can I use a dax gearbox on a predator?
Dax chain gear box will not work on a Predator which has a ~ 5/8" diameter shaft output.
AGK is the only place that I know of that sells parts specifically
for the predator motors.
The motor plate from agk comes drilled to fit the 99 cc but
still needs the end frame mounts or you can weld it to your
frame.
http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=2306&Category_Code=99cc
