For no good reason in particular, I bought a new clutch, just the inside with shoes part, from Bicycle Engines .com. I had a bunch of questions which BE people answered and they sent my new clutch very quick. Those guys are good.
When I put the clutch on and ran the bike, I was surprised to see how quickly in engaged. Right off idle. I decided I needed the engine to be more in its power curve before the clutch kicked in. So I got some washers and took the clutch apart.
The springs were a surprise. Very much lighter than the ones in my original clutch. So I changed them over and now everything works fine.
This new clutch engages lots smoother than the older one did. The new one has a pattern on the shoes that looks like a tire tread. The shoe material seems a bit softer too.
If you are a lightweight, you may like the low rpm engagement. But if you are a 'widebody' like me, having some power built up before engagement is a good thing.
Bottom line? The new clutch is smoother than the older one, but you may want to change the springs out.
![dance1 dance1 dance1](https://motorbicycling.com/images/smilies/dfl.gif)
