Before riding today, I checked the crank bearings, no play, move freely and smoothly. Just to play it safe, I replaced the piston, piston rings, and needle pin bearing for the piston.
Took it out for a test ride and after 15-20min, the engine seized completely. Before it seized, it still had that loudness at higher RPMs, even with new gaskets and a new exhaust. I took off the cylinder head and found the piston completely stuck in the cylinder. I couldn't move it with my hands. I tried looking through the exhaust port to see if anything was stuck, but it looks fine. I am guessing the new ring got caught on something. The cylinder walls were perfect (no gouges, no scratches) and smooth right before today's test ride. Ever since I started having problems with this engine, I couldn't get it back to normal working condition.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I decided to try out my previously rebuilt RAW engine, while it runs fine, it's top speed is no where near close to what it was able to do brand new and it is weaker as well. I don't understand why it can't go as fast as it preivously could. I have new piston, new piston rings, new cylinder head and jug, new spark plugs, new gaskets, new exhaust, new crankseal, and new carb. The engine idles fine and there are no air leaks anywhere. I can't figure out why it won't run as powerful or fast as it did brand new.
