First in progress
Easiest way for me is to use a photo uploader. Photobucket, picasa, ect., one of those sites should get you in the right direction... let us know.
When you post a reply or message scroll down passed where you type and it says attach files. Or on quick reply you can click go advanced and it gives you option to attach or hit the little paper clip above the box you type in
THANX.
IT DID HAVE THE SECOND BAR LIKE A SCHWINN, BUT I HAD TO CUT IT OUT. MESSED MY PAINT UP PRETTY BAD BUT IT LOOKS GOOD IN PICS..LOL
DANG THANG IS SO LOW IT SCRAPES THE GROUND WHEN YOU HIT DIPS OR SMALL CURBS.
IM GONA HEAT AND BEAT IT A LIL TRY AN GET SOME CLEARANCE.
I HAD TOO USE THE OFF SET INTAKE AND I CANT USE MY AIR FILTER,
THE CARB IS TO CLOSE TO THE FRAME.
I SHOULD BE ABLE TO HEAT AND TWEAK IT RIGHT??THE INTAKE THAT IS.
thanx.
It did have the second bar like a schwinn, but i had to cut it out. Messed my paint up pretty bad but it looks good in pics..lol
dang thang is so low it scrapes the ground when you hit dips or small curbs.
Im gona heat and beat it a lil try an get some clearance.
i know what you mean about low and scraping!!!!
