these pots mentioned ,would they be the same as a volum adjuster in a radio,if so u could adjust the spark like on a harley or model-T ?I will be building two more MBs during the colder months here in the US and will give that circuit a whirl on those bikes.
That is exactly how it looks to me under magnification.
Okay, so what is the little component that looks like a diode but has the squiggly line instead? I do not remember that symbol.
Rode for 15 miles yesterday with a new factory carb. Had a small stutter for a lil bit and figured it was some crap caught in the carb that finally broke free. Set out on my commute this morning ang 1/2 mile out from home she dies...hard. Pedal back and drive car to work. Checking my CDI first because I made it and want to be sure it's ok. I didn't totally air-tight my box and I found some condensation inside as well as telltale signs on some of the diode leads. Then I saw it, burnt my 82ohm resistor. Changing resistor and sealing the box then we try again.
Sorry to hear that you are having problems with the CDI.
You do know how to test an SCR, right?
Or do you need a schematic for a quick little SCR test fixture?
Awesome, Thank you. I replaced the SCR and tested today. Still dead. I have a real nice 12 volt dc power supply I can use to test the scr.
Forgot to ask what size bulb? Maybe an auto tail lamp bulb?
