They dont use tubes anymore....
Just tryin to help!
I think the first component is a black diode. The diode across the bottom of mine is a glass diode.
Black diode then resistor then black diode then another black diode then scr and the bottom diode is like the first one in the picture.
I believe the capacitor went to the scr and then to the coil, but I'm not positive since it broke off when I was trying to get it apart.
Sorry, I'm a bit rusty on my electronics. I haven't really done much electronic work in over 20 years.
On your PCB, the first component looks to be a glass diode?
We know that the black diodes are the standard 1N400x series, and that the SCR is a standard off the shelf device, like a C106.
The next challenge is to figure out the value of the resistor and the zener diode.
The typical SCR used in this type of application usually has a peak gate voltage of 5 V, so the zener is going to have a value less than that.
Zener voltages start at 1.8 and go up from there.
Time to break out the cakeboard and do some prototyping.
What you are seeing are the ribbed metallic film insides of a capacitor, part of its orange-red outer covering can be seen still stuck to the resistor in the photo.
