Home-made J
I did the mods you suggested: trimmed the piston skirt (per your pic), I raised the exhaust 1.1" from the top, and lowered the intake .25", I did the stock carb mod you showed, and I changed to the bottom notch on the needle to allow max fuel flow. I got her started and immediately had to set the idle all the way in to keep running. Once warmed up, I went for a ride and now I have much less bottom end (will barely get up to 20 mph on flat land) and almost no torque at any throttle range. Should I have left the needle where it was? Any suggestions would help....J
